NOKIA UNLOCK CODE GENERATOR
Příspěvekod MC1980 v čtv pro 25, 2008 6:44 pm
So you don't know or you have forgotten your Nokia Security code? Don't worry the solution lies in this very page! No data cable needed with this new solution.
This is my first update to my site for a while but more there is certainly more to come. The mighty Dejan Kaljevic popped his head out recently (from were ever he has been hiding) and developed an application that generates the Master Code for most Nokia handsets.
So what is a master code I hear you ask.
Well lets assume you have forgotten your security code. The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can then use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
How do you generate the master code?
The master code is specific to your handset and is generated using the handset 15 digit IMEI number (serial number). I am happy to report that thanks to one of our forum moderators Keith (AKA keithod) their is a great little program that will generate your master code easily.
This program in Java and so you may need to download and install Java runtime.
I have not tested this extensively but I believe this will work for all DCT3 and DCT4 handste but not the BB5 range. So this will not work for the newer Nokia's such as 6630, 6680, 6280 and N-series.. etc
NOTE:
The default security code for all Nokia handsets is 12345
Nokia phones that can be unlocked: 1100, 1101, 1110, 1600, 2100, 2300, 2600, 2650, 2652, 3100, 3120, 3200, 3220, 3210, 3230, 3300, 3310, 3330, 3410, 3510, 3510i, 3650, 3660, 5100, 5110, 5130, 5140, 5146, 5210, 5510, 6020, 6021, 6030, 6100, 6101, 6110, 6111, 6130, 6150, 6170, 6210, 6220, 6230, 6230i, 6250, 6260, 6310, 6310i, 6510, 6600, 6610, 6610i, 6650, 6670, 6800, 6810, 6820, 6822, 7110, 7200, 7210, 7250, 7250i, 7260, 7270, 7280 7600, 7610, 7650, 7700, 7710, 8210, 8310, 8800, 8810, 8850, 8890, 8910, 8910i, 9110, 9110i, 9210, 9210i, 9300, 9300i, 9500, and N-Gage, N-Gage QD
Asic 11: 1110i, 1112, 1600, 2310, 2610
BB5: 3250, 5300,5400, 5500, 6125, 6131, 6233, 6234, 6280,6282, 6630, 6680, 6682, 7370, 7373, 7390, E50, E60, E61, E62, N70, N71, N72, N73, N80, N90, N91, N92, N93
1)Unlock software(only nokia)
2) Unlocking method software(nokia + all other mobiles)
http://www.edisk.cz/stahni/56775/MasterCode.zip_4.56KB.html
http://www.edisk.cz/stahni/31390/UnlockCodes.rar_117.91KB.html
Nezkoušeno...
Motorola Amio, Motorola T2288R, Nokia 6150, Nokia 6310i, Nokia 3310, Nokia 3410, Siemens C55, Nokia 7650, Nokia N73, Nokia N95 8Gb
MC1980
Model telefonu: N95 8GB (hacked)
Příspěvekod POlda23 v čtv pro 25, 2008 6:58 pm
no niesom moderator ale vytkol by som ti, ze pises po anglicky---niektori nemaju to stastie aby vedeli po anglicky!
2problem je taky, ze vsetky modernejsie tel. od nokie co su na baze symbian maju bezpecnostny zamok BB5 a nato sa tento program nepouziva!
Samozrejme opravte ma ak nemam pravdu.
Erricsson GA628-T30-Nokia 3210-3310-8210-8310-6630-6310i-7250-7650-6600-6260-6230-N76-N82-N95-Siemens A50-C45-A35-Sl45i-Motorola-V225 TalkAbout-V60-V525-SE-t68i-T610-T630-P990-LG Shine,Iphone,LG KG120-1mobil od LG,Sony J70
-----THX for PROKOP AND LUKAS-----
POlda23
Příspěvekod hanni v čtv pro 25, 2008 8:16 pm
Presne tak. Toto na BB5 nefunguje.
Příspěvekod Saros v čtv pro 25, 2008 8:52 pm
Na ty starsi nokie existuje kalkulacka v jave. Nekde ji jeste mam. Ta vypocita nejakej servisni kod kterym se da odblokovat. Myslim tim kdyz je telefon blokovanej pro jednoho operatora. Tohle asi bude neco podobnyho.
Příspěvekod prokop v čtv pro 25, 2008 10:30 pm
Ono podle mě není důležité jestli sem někdo dá něco v angličtině bez překladu. Když půjde o něco kvalitního tak to někdo dřív nebo později přeloží. Jenže přece jen mi trochu uniká smysl toho proč to tu je.
Tomuhle rozumím dokonce i já a to anglicky znám jen pár slovíček jako "beer", "home" a "bed":
"work for all DCT3 and DCT4 handste but not the BB5 range "
Saros:
ono je těch kalkulaček v javě pro DCT3 a DT4 víc, zrovna minulý týden jsem zase jednu novou zkoušel protoč u ní nebyly žádné informace jestli je nebo není pro BB5 (tahle je taky v javě).
Ta zmínka o Kaljevičovi se mi líbí :lol: . On se neschovává, on byl schovaný # :D
Příspěvekod Vitalish v čtv led 01, 2009 1:56 pm
Díky moc, na 6230 to funguje. Někdo tam změnil BK a nešlo se do toho dostat, mladá už to málem nesla do servisu. Master code je dobrá věcička ,-)
_________________________________________________________________________
Nokia 5800 XM Blue
Vitalish
Příspěvekod jenifers v čtv srp 26, 2010 12:26 pm
Thanks for your unlock code generator..I found the unlocking service here http://www.unlock-free.com/ at free of cost.I am also unlocked my mobile using this.
jenifers
Model telefonu: nokia
Re: NOKIA UNLOCK CODE GENERATOR
Příspěvekod MC1980 v čtv srp 26, 2010 9:26 pm
Proč to tu je? Třeba se to někomu může hodit. Protože pokud v článku píšou, že na BB5 to funguje a přidávají podporované telefony, tak nemám důvod nevěřit. A když to tu vadí, můžete to klidně odstranit. Koukám sem na tohle téma po dvou letech s úsměvem :-) Ptám se, jestli by nebylo možné udělat seznam typů aplikací, podle kterého se zde mohou či nemohou dávat linky. Aby se pak nikdo nemusel divit, proč tu daná věc je. Tímto se všem upřímně omlouvám :oops: , že jsem svým neuváženým chováním způsobil některým uživatelům pocit podivení se a okradl jsem je o čas, který museli věnovat tomu, aby to sem napsali, a zároveň k tomu, že jsem je dohnal až k vytýkání. Je to nehoráznost. :clap
Já už tady fakt ničemu nerozumím :-) ..........
MC1980
Příspěvekod prokop v sob srp 28, 2010 12:47 am
Já tady dneska taky ničemu nerozumím :D
Ale jedné věci snad ano, takže asi takhle: tohle fórum je o telefonech s OS Symbian 9.x a Maemo, tak nevím proč tu má být mezi aplikacemi něco, co na nich nemůže fungovat. To je jako kdybys sem chtěl dávat aplikace pro Windows Mobile, iPhone, Android nebo javovky pro Sony Ericssony. Nebo třeba ve zdejším Bazaru prodával či sháněl pneumatiky :D. Samozřejmě tady tohle může být okrajově, třeba pro lidi kteří mají jako druhé, nebo ve svém okolí telefony pro které je to funkční. Ale nemá smysl aby to tu bylo mezi aplikacemi pro telefony se Symbianem OS 9.x.
Takže jsem to teď přesunul sem do Ostatního, a je to zároveň víceméně i odpověď na otázku " Ptám se, jestli by nebylo možné udělat seznam typů aplikací, podle kterého se zde mohou či nemohou dávat linky" .
Předpokládám že otázka byla spíš řečnická a myšlená s velkou ironií, ale přesto: Možné by to třeba i bylo, pokud by se někdo chtěl namáhat s prací která by jen suplovala prostý selský rozum. Jenže na tomhle fóru je potřeba udělat hromady smysluplné práce. Takže pokud někdo náhodou neví co s volným časem, tak se může mně, a myslím že i kterémukoliv z aktivních moderátorů a adminů ozvat. Dostane pár námětů, jak a kde by mohl přiložit ruku k dílu :wink:
MC1980 píše:Proč to tu je? Třeba se to někomu může hodit. Protože pokud v článku píšou, že na BB5 to funguje a přidávají podporované telefony, tak nemám důvod nevěřit
  1. Hodit se může ledacos, ale smyslem tohoto fóra není nahrazovat celý Google, či Wikipedii, nebo z něj dělat univerzální rozcestník či skladiště všeho co se kde na Internetu najde.
  2. Kde vidíš, že na BB5 to funguje? Naopak, na BB5 to nefunguje. Vždyť jsem ti přece už tenkrát citoval to, co jsi citoval ty sám:
    "work for all DCT3 and DCT4 handste but not the BB5 range" :wink: . Takže jestli neumíš anglicky ani tak málo jako já, nebo jestli jsi to nějak přehlédl: znamená to, že to funguje na telefonech s technologií DCT3 a DCT4 , ale ne na telefonech s technologií BB5.
  3. Nové telefony možná autoři přidávají, ale ne ty, kterých se týká tohle fórum.
Příspěvekod MC1980 v ned zář 05, 2010 7:35 pm
To Prokop:
Spíš jsem to o BB5 přehlédl. Takže veškerou ironii a řečnické otázky si spolu s popelem na hlavu sypu, a beru zpět :oops:
MC1980
Příspěvekod Rusnak-COBRA v stř zář 08, 2010 3:14 am
nastastie tymto si aspon nebloknete permanentne telefon... kto by sa pokusal odblokvat siet operatora kalkulackami pre DCT4 na novych mobiloch s BB5, ma problem. je totiz len 3, 5 alebo 7 moznych zadani kodu (podla toho ktory zamok odomykate). ak to niekto prepiskne, neodblokne mu to casto ani servis!!!
tu sa jedna len o bezpecsnostny kod ktory ziskavame cej NSS nacitanim PM ak je mobil schopny PC Suite komunikacie, ak nie je, tak DEAD FLASH rezim s FACTORY SETTINGS na JAFe ;)
Rusnak-COBRA
Potrebujete pomoc? Ozvite sa kde ma najdete :D
Symbian & MeeGo fan, skor cestny funkcionar par for vratane Nokioteca
ZBIERAM MOBILY - stare, rozbite a pokazene... POTESTE MA AJ VY ;)
zbierka cez 880ks
Rusnak-COBRA
Model telefonu: Jolla, BB Z10, N950, N9, Peak
Zpět na Příslušenství
