EndClear [25.12.2011] (EN,RU,CN)
Příspěvekod pyler v sob led 01, 2011 10:34 am
EndClear v1.20 S60v3 FP1 FP2 EN
EndClear - Powerful garbage phone
This is an application (automatic or manual) is very strong on the Symbian phones. It will clean up all kinds of garbage on your smartphone: Something from the installation or uninstallation, from browsing the Web, view pictures .... with a single click.
In addition, it also includes integrated file management program allows you to cut, paste, rename, set password for files, folders ...
Specially, it included the pyUninstaller app very familiar and famous of Russia that you can cleanly removes any applications installed on the phone: Sis, Java, themes (theme) ...
EndClear_S60v3FP1_FP2_v1.20-EN.rar
(92.11 KiB) 420 krát
Naposledy upravil pyler dne úte pro 27, 2011 11:35 am, celkově upraveno 6
Re: EndClear [1.1.2011]
Příspěvekod pyler v pát dub 01, 2011 4:58 pm
EndClear 1.50 (1.4.2011)
Autor: 飞雨漫天@ZnTXPDA
! - je to v CN :-D
EndClear 1.50 cn.zip
(94.11 KiB) 194 krát
Ru verzia by horrid71 :-D
EndClear_v1.50(0) ru.zip
(93.66 KiB) 159 krát
Příspěvekod pyler v sob dub 09, 2011 8:43 am
EndClear 1.60 cn (9.4.2011)
EndClear_v1.60_cn.zip
(101.21 KiB) 166 krát
EndClear 1.60 ru by horrid71
EndClear 1.60 ru.zip
(98.46 KiB) 134 krát
Re: EndClear [14.5.2011] (EN,RU,CN)
Příspěvekod pyler v sob kvě 14, 2011 9:12 am
EndClear 1.70 Unsigned EN By Xitrumbinhduong
Version 1.70 is updated as follows:
1.New the graphical Menu.
2. Add search plugin limit independent professional junk removal
3. Add optional cleaning applications.
4. Added option to clean system.ini
5. Added option to clean the thumbnail image cache RV
6. Added option to clean the UC cache
7. Loading mode as the optimization program
8. Cycle optimization of memory consumption.
9. Optimize and fix from unknown sources
EndClear v1.70 EN .zip
(159.65 KiB) 229 krát
Příspěvekod pyler v čtv kvě 26, 2011 10:46 am
EndClear 1.80 ru
What's new:
1. Optimize code for better compatibility with other types of screens.
2. Search term fix, delete the file name.
3. Fixed limit your search to delete all.
4. reconstruction of the interface.
5. Improved speed of the scanning, cleaning.
6. Split function set up and install the modules installed.
7. 240 * 320 screen is more functional interface converter in the main interface
8. Enhance error prevention mechanisms to reduce the overall run time error.
9. At the main menu, press the OK button to start the scan.
10. Please note: if you select automatic cleaning function, the program will delete spam immediately after scanning.
EndClear_v1.80_ru_250511.zip
(171.62 KiB) 209 krát
EndClear 1.80 EN
EndClear v1.80 EN.zip
(151.78 KiB) 175 krát
Re: EndClear [26.5.2011] (EN,RU,CN)
Příspěvekod IMP v úte kvě 31, 2011 10:11 pm
EndClear 1.90 EN
What's new:
1. Add to delete junk data.
2. Fix known bugs from previous versions.
Endclear v1.90 EN.rar
(150.81 KiB) 160 krát
IMP
Game Moderátor
Game Moderátor
Model telefonu: Nokia N95 8GB + Nokia N73
Příspěvekod pyler v pon čer 20, 2011 11:29 am
EndClear v2.00 S60v3 v5 SymbianOS9.x Unsigned EN By Xitrumbinhduong
What's new:
- Fixed small bug to delete the configuration
- Optimizing the rate of cache after exit
- Optimization of junk data grouped together
- Increase the number of paths to eliminate waste
- Compatible with S60v5
- Enhance Find a mistake to judge removed
- To enhance the overall structure of the source code for optimal
EndClear_v2.00 EN by Xitrum.zip
(154.63 KiB) 213 krát
Re: EndClear [4.11.2011] (EN,RU,CN)
Příspěvekod pyler v pát lis 04, 2011 8:16 pm
nova verzia 2.10 en ..
http://upwap.ru/1812602
Re: EndClear [5.11.2011] (EN,RU,CN)
Příspěvekod IMP v sob lis 05, 2011 9:59 am
EndClear v2.10 s60v3v5 SymbianOs9.x unsigned En translated by Shankru
What's new:
- add the latest large-scale garbage database
- optimizer source in many small BUG
- Fixed some model error issues
- font fix part of the accidental deletion of junk path
- continue to strengthen the software source code optimization
- solve the coverage problem installing error
EndClear v2.10 EN by Shankru.rar
(168.51 KiB) 228 krát
IMP
Game Moderátor
Game Moderátor
Příspěvekod pyler v úte pro 27, 2011 11:34 am
databazovy patch do EndClear 2.10
EndClear_20111225_pu.zip
(10.03 KiB) 156 krát
Re: EndClear [28.7.2012] (EN,RU,CN)
Příspěvekod IMP v pát črc 27, 2012 11:50 pm
EndClear v2.30 S60v3 v5 SymbianOS9.x Unsigned EN By Xitrum
What's new:
- Update latest garbage database
- Fixed some small bugs
- Continue to increase the number of deleted garbage path
- To further enhance the source code optimization app
- Add more information files[/list]
Download:
http://uloz.to/xtVFUms/endclear-v2-30-en-by-xitrum-rar
IMP
Game Moderátor
Game Moderátor
