RunPy [2.2.2013]
RunPy [2.2.2013]
Příspěvekod pyler v sob úno 02, 2013 7:10 pm
RunPy_3rd 直接运行py脚本
Popis
[Language]: Chinese
[Version]: 0.1
[Tariff]: Free
[Software Category: System Tools
File Description:
The resources 1 main program
The resources 2 is associated plug
Association. Py script, click directly run the script, the equivalent of double-click on the computer executing the script, the practical significance is not great like dedit not running the editor may use some help, there is too lazy to pack the Friends of the script Friends of chances also useful. Some bug, such as exception script error, direct exit exit normally need to press the Escape key twice, the no exit function script needs to kill the process to exit.
No icon after installation, click on the script tests directly in the file manager, such as platform comes ball.py But this script is not exit the program!
Third Edition Fifth Edition S ^ 3 should be universal.
v skratke, v spravcovi suborov kliknete na *.py subor on skript sa spusti..
najskor treba nainstalovat Pyrecog.sis potom RunPy.sis
zdroj:
http://sjgs3.lexun.com/bbs_detail.aspx?forumId=5690&topicid=47448139&topic_page=1&istop=0&topic_cid=0&cd=0&lxt=8b831ee048a90690sqrsrccrsf&forumID=5690&vs=1&pid=5690
RunPy_pyrecog.zip
(7.2 KiB) 118 krát
