OpenDUNE
OpenDUNE
Příspěvekod IMP v stř úno 22, 2012 2:59 pm
OpenDUNE is an open source re-creation of the popular game “Dune II”, originally made by Westwood Studios, and released by Virgin Entertainment.
It attempts to re-create the original game and apply modern technology to it to allow it to be run natively on most operating systems.
The S60 version of OpenDune is based on the pre0.8 version.
Midi is enabled by using a special version of sdl_mixer which has a scummvm midi player which supports the xmidi format.
You can change the music file used by supplying a different dune.cfg file (or use the dos setup program to change).
The different configs to use are supplied in the same folder as this read me (c:\data\opendune)
1. Pc Speaker uses the single channel midis
2. Tandy uses the three channel tandy midis.
3. Sound Canvas is using the C55 midi files.
4. Rest (adlib, mt32, sbpro) is using the xmi files.
The game supports bluetooth mouse and keyboard.
To enable game play on the regular phone the following mapping has been implemented.
To get normal numbers where needed, use *+number key.
Keyboard Commands:
0 - A - Attack
1 - B - Build It
2 - D - Deploy or Destruct
3 - G - Guard
4 - O - On Hold
5 - P - Place It
6 - R - Retreat or Return
7 - H - Harvest
8 - U - Upgrade
9 - S - Stop
# - M - Move
'*+C' - Q - quit
Installation Instructions:
  1. Install SISx file
  2. Put data files to the root on memorycard i.e e:\OpenDune\
  3. Enjoy ! ;)
Download:
  • SISx:
    https://sites.google.com/site/anotherguestpage2/opendune_s60v3.SISx
  • Data Files:
    https://sites.google.com/site/anotherguestpage2/OpenDune.rar
IMP
Game Moderátor
Game Moderátor
Model telefonu: Nokia N95 8GB + Nokia N73
Zpět na Portované a emulované hry
