Nokia 701 - RM-774 - DELIGHT CFW v1.0 - všechny jazyky
Příspěvekod freaxs_r_us v stř úno 19, 2014 8:37 am
FAQ, Backup and Restore Documentation, Delight Resolver Documentation are in HERE
Delight team:
- huellif - main developer & cooker
- freaxs_r_us - translator & cooker
Special thanks goes to nicesoni_ash, for his help, knowledge and support.
This CFW has been created with NokiaCooker. Consider donating for Free and High Quality softwares.
http://www.symbian-toys.com/NokiaCooker
IF YOU WANT TO RELEASE THIS TO A FORUM OR BLOG YOU KNOW,
THEN PLEASE ONLY WITH OUR DIRECT LINKS
please don't forget to share us, like us, twitter us & follow us on the blog
Read FAQ Provided with flashing files and then ask other questions.
THESE FILES ARE RE-PARTITIONISED!!! DO NOT MIX WITH OTHER FIRMWARES!!!
Contributors:
- Allstar12345 - theme effects maker
- Cahjoss - Conversation skin maker
- Lao Stia - Theme maker
- Mahindar - Widget mifs
- bhavin192 - Keyboard skin maker
Link your post to our blog for files and changelogs if you want to post it somewhere else
FAQ, Flashing Tutorial, Backup and Restore Documentation, Delight Resolver
Documentation are in Faq Link.
Note:
This is a completly new CFW, based on Belle Fp2 113.010.1506, product code
059H029
cooked by huellif and freaxs_r_us
Special's in this CFW:
After Flashing complete,
your phone will restart once showing you different
notifications. Let it do its work.
After restart, you are all set to go.
What does this mean?
Simple answer, the UDA is empty, all files form UDA are in ROFS and get copied to C:\ after first boot or a hardreset.
- in Menu, Tools, Xtras you will find three apps: backup, restore and resolver and now updater
Check their documentation in Additional Files folder.
**Check Change Log Here**
C:drive after flash is minimum 608mb
RAM: 295mb
Added mods:
• ROMPatcher 3.1 FP2
• Domainsrv.exe mod
• installserver_log CODeRUS
• tactile feedback for calls
• SoundImprovment 3.5 (Anna sound config + more volume)
• akncapserver (faster taskswitcher)
• ID3 editor
• EQ editor
• unlocked menu (subfolders, app renaming)
• Delight Menu (you can revert to original Symbian Belle menu via Delight App)
• short multitap
• predic on E:\
• smilies in all apps
• SysAp mod 1.4 (disabled FMTX popups, unlimited SMS sending retries, save log after SIM change, disabled charger and volume popups, browser and network queries, PSM notes and autoswitch, reboot via long press powerkey)
• ported theme effects on/off option
• ported touch input options (adaptive search)
• you can completly close all system apps
• sip client
• power & profile symbols
• Voice Recorder 5Hours at 256kbps
• increased maximum SMS size (30 SMS)
• modified swipolicy.ini (more rights with devcert and less warnings)
• keyboard fast mod by Allstar12345
• exclusive keyboard skin by bhavin192 (you can choose other skins via Delight App)
• Picture viewer works in :\private\ folders
• torch mod, now you can enable torch via lock key in power saver mode
Added apps:
• Delight App
• SMS Themer
• LCG X-Plore
with full filesystem read access and full write access of :\private\ without of Open4All
• s60v5's GPS Data
• Noka Internet Radio with widget
• Connectivity Analyzer
• Photo Editor from N8 (you still can access FP2 editor from gallery)
• Video Editor from N8 (you still can access FP2 editor from gallery)
• MIFeditor
• FreeUnRAR
Settings:
• disabled product improvment
• enabled dolby by default
• menu a-z by default
• infinite browser cache at E:\
• splashscreen.mif from C:\
• disabled NFC by default
• preset camera default settings
Deleted:
• Nokia Music
• QuickOffice
• F-Secure
• Adobe Reader
• YouTube
• JoikuSpot light
• World Traveler
• Vlingo
• Nokia Social
• Bounce Boing Battle
• Microsoft Communicator
• Shazam
• Nokia Recommends (+ widget)
• CNN
• Public Transport
• default Backgounds
• NFC tutorial
• MS Office samples
• Video Pro
• Silent Film Director
• Nokia Weather and Weather widget
if you like to: you can reinstall some of them via http://n8delight.blogspot.com/p/downloads.html or go to menu, tools, SW Update
removed other:
• offline queries
• Priority Of Aknspasrv (improves the battery life a lot, but causes small blackouts in gallery)
• USB popups
• popup fader (C++)
• reduced QML popup fader
• FOTA
• OVI SMS signup after first boot
• change theme popup (it works much faster)
• disabled no connection popup
Screensavers:
• Animation
• Music Player
• SlideShow
• by default no Screensaver
Integrated Updates:
• 3G network compatibility fix
• Application compatibility fix
• Email and Calendar update
• FIX for Messaging
• Gallery and Camera update
• New homescreen widgets
• Nokia Store
• SMS Update
• Telephony update
• WIFI update
• YouTube ShareUI fix
• Facebook ShareUI fix
• Twitter ShareUI fix
Themes:
• Delight Theme by Lao Stia
• Evolve Qt 3.0 For FP2 by SLAYER33
• Transbelle Lighthouse Theme
• Delight conversation skin by Cahjoss (you generate your own skins via SMS Themer)
Theme Effects:
• Smooth As Hell V4 by Allstar12345
• effects are loading from E:\effects
Widgets Added:
• Anna Notifications (incl. Belle Icons) + a 2*2 version
• Clocks: analogue – small, profile, small digital, text small
• Contacts: mini, comms
• Small versions of: DLNA server, WIFI, FM-Transmitter, Calendar, Notes (exclusive), Webview, Music Player
• Internet Radio
• Mail One Line and Two Line
• Search and Search Mini in ROFS
• ported Vertu Apps Launcher
Widget Skins from:
• Xinox
• Kang Shao
• SelvaSathyam
• Teom@n
• MrKenkadze27
• Mahindar
You can replace all skins which are in C:\resource\apps with your own (without wasting RAM via joshlog/iChris patch).
To restore default/delight skins check Delight resolver documentation.
Some widgets need joshlog or flashing: all email, all contacts and bookmarks widget.
Known issues:
• you tell me
Download & Translations
Delight 701 release - At the BLOG
FAQ download here
Please don't reupload/mirror this CFW, this isn't a slow hoster or an adversitment page like adf.ly
Translations & Info
Instructions:
Notice: only english version has all files needed
1. Just get the download from the blog
2. get the translated rofs2 = Ui translation from me if desired
3. exchange the rofs2 you got from me with the one in the full cfw set
4. get a writing file rofs3 if you need additional writing files
(the rofs2 translations has the chosen writing files)
5. exchange the rofs3 you got from me with the one in the full cfw set
Translation features:
- ALL needed standard files in your language (if provided by Nokia)
- ALL needed modded files that need translating to work
- IF TTS (text to speech) is available in your language, then it is included
- ALL translations have english as base files
- all writing and keyboard files
- all dialer files
- added ecom-3-0.spi which can handle ALL languages
- translated all new widgets and corrected old ones (I corrected over 500 strings)
- text clock widgets in your language; translations by wirer
for now only 02, 03, 04, 17, 18, 25, 27, 42, 54, 68, 76, 79 ... maybe more later
Known "Issues":
- Third party Applications, for example: ROM patcher+, are not translated
- in more than 1 language packages there will be only english text clock
- metadatamod equalizer mod in english
- rarely used languages, such as galician, basque, canadian french, chinglish & taiwan english are not made
Credits:
testers:
- mahindar
- a.hamameh
- bhavin192
Thanks for your help :)
Mod providers:
- Il.Socio - Rompatcher, Nokia Cooker and a lot more.
- CodeRUS - A lots of mods.
- iChris701 - For his mods and help
- iExtraX7 - Several mods.
- Ancelad - Tactile Feedback and few other mods.
- witcher3 - Menu organized
- xCape - Mod and few tips on widgets and a lot other stuff.
- Lovelas - few ported screensaver.
- moki - Fixed font problem.
- Cigiampa/xCape - Script files
- 7b - More Icons in Power Menu
- Stephan020793 - his tutorials were my first step into Symbian modding
- strategist - for his camera mod
- MoritzJT - his help with fonts
- Symbian Fan - for help with product improvment
- Robo3737 - for his widgets
- Skull-ATOS - for screensaver
- Joe3, M4C351, peoresnada - for notifications widget
- RedX - for his legendary cenrep informations
- omkarkul - for his mods
- BelleXDesigns - for X-Plore icon & NEW backup, resolver, restore, updater icons
- aniket - single communication contact widget
- haqanguven - the web browser fix
- Turek - Notification lights ON, Menu Lights OFF mod
- TheOne - Text under HS icons sis - installer/deinstaller
- aamirx64 - for original TransBelle theme
- MMMOOO for transparent icon sets
and everyone who helped me in one way or another..
Let me know if I missed something and I would add your name in here. Thanks.
Hope you enjoy this version too.. :D
Post your views, suggestions or any bug report... Thanks.
Kindly
read FAQ file for your troubles and if you don't get the answer of your
problems in there, than only put your question here.
if you want to know whats going on first hand...follow us
by adding your email to this on the right hand side of the blog:
and recieve emails as soon as something changes
help us helping you
the more followers we have the better for the blog
And don't forget to "like" us on facebook
"share" us on google
and anything else you use
freaxs_r_us
Příspěvekod Turek v stř úno 19, 2014 10:21 am
huellif@ & freaxs_r_us@, I greatly appreciate your work, and I am very glad you have not forgotten our forum. Thank you for the post.
