Nokia 808 - RM-807 - DELIGHT CFW v1.4 - všechny jazyky
Příspěvekod freaxs_r_us v stř úno 19, 2014 10:26 am
Update: v1.4
FAQ, Backup and Restore Documentation, Delight Resolver Documentation are in DelightApp.
Changelog 808 Delight v1.4:
Changes:
- removed Nokia Weather and Weather widget
- added remove Recording tone patch
- added full filesystem read access to X-Plore and full write access of :\private\
- Picture viewer works in :\private\ folders
- torch mod, now you can enable torch via lock key in power saver mode
- EvenFaster patch for ROMPatcher, which allows you to enabled/disable torch via lock key much faster
Added:
- exclusive keyboard skin by bhavin192 (you can revert to original one via Delight App)
- Photo Editor from N8 (you still can access FP2 editor from gallery)
- Video Editor from N8 (you still can access FP2 editor from gallery)
- Unit Converter from s60v5
- GPS Info app from s60v5
- Delight SMS Themer
Fixes:
- Email widget font Delight style white
- Note widget font Delight style white
- cleaned sisregistry
- Sysap 1.4 by iChris701, now it will show SSL cert popups like on original firmwares
Updated:
- Menumatrix to show Unit Converter in Organiser & GPS Info in Navigation
- Updated Delight App to 1.3.0
Widget skins: new by Mahindar
- DLNA big & small
- WLAN big & small
- VPN toggle
- Operator
- Stopwatch
- FMTX small
- Mirror
Themes:
- Delight theme updated
- added "Evolve Qt 3.0 For FP2" theme by SLAYER33
Effects:
- Smooth As Hell V4 by Allstar12345
Delight App v1.3.0
Added:
- manual scrolling settings to Selector
- manual light settings to Selector
- FM Transmitter RDS tag chooser to Selector
- FP2 keyboard skin Selector
- Credtis page
Other:
- performance improvments
- some fixes
- rearenged code
- browser fixer is working on the fly
how to update?
a) if you flashed v1.0/v1.1:
- flash via "Update Software" and without UDA
- after flashing run the app "Updater" will start by itself, select:
    [li]v1.3 if you were on v1.2 before[/li]
    [li]v1.3 and v1.2 if you were on v1.1 before[/li]
    [li]v1.3, v1.2 and v1.1 if you were on v1.0 before[/li]
and let it do its job.
=> You will get all changed without of a Refurbish and loosing drive C:\
b) you didn't flash v1.0/v1.1/v1.2/1.3 before:
you have to flash the whole CFW via Refurbish.
Download: via Delight blog
Links for additional files, documentation, deleted sounds and rofs3 versions are also on our blog.
Have fun and please share feedback ;)
freaxs_r_us
