Nokia C6-01 Delight Custom firmware v1.0 - všechny jazyky
Příspěvekod freaxs_r_us v stř úno 19, 2014 10:31 am
C6-01 Delight v1.0 - provided by Padrino
Padrino was kind enough to send me his C6-01 for developing. So big thanks going his way for sending his phones.
Please sign the Petitions linked at the top of the blog post
please don't forget to share us, like us, twitter us on the links
New exclusive Delight app - the SMSThemer
opens the gallery and you can choose any picture for the messaging background skin
it automatically resizes any picture to 640x640
And of course lots more changes to the cfw...
Delight team:
- huellif - main cooker
- freaxs_r_us - translator and second cooker
Delight contributors:
- Allstar12345 - theme effects maker
- LAO STIA - theme maker
- Cahjoss - conversation skin maker
Special thanks goes to nicesoni_ash, for his help, knowledge and support.
This CFW has been created with NokiaCooker. Consider donating for Free and High Quality softwares.
Pictures are from a different phone and may vary
This is the special DELIGHT THEME: made by LAO STIA
you CAN use, but you do NOT HAVE to use it
this is the special Delight conversation theme made by Cahjoss
if you don't want to use it, then just use the Resolver/Selector/conversation skin selector to change it back
Read FAQ Provided with flashing files and then ask other questions.
Link your post to our blog for files and changelogs if you want to post it somewhere else
FAQ, Flashing Tutorial, Backup and Restore Documentation, Delight Resolver
Documentation are in Addtionial Files folder on Mediafire.
This is a completly new CFW, based on Belle 111.040.1511, product code
059C013 cooked by huellif and
Special's in this CFW:
After Flashing complete,
your phone will restart once showing you different
notifications. Let it do its work.
After restart, you are all set to go.
What does this mean?
Simple answer, the UDA is empty, all files form UDA are in ROFS and get copied to C:\ after first boot or a hardreset.
- in Menu, Tools, Xtras you will find three apps: backup, restore and resolver and now updater
Check their documentation in Additional Files folder.
Flashing Information:
- when coming from a different firmware you MUST flash via refurbish
This is a completly new CFW, based on Belle Refresh 111.040.1511, product code
C:\ drive after flash is minimum 370 MB
RAM: 145 MB
- all Delight flashing file settings:
- extended CORE/ROFS1
- unlocked CORE
- cleaned CORE
- changed purpose and sw text
- cleaned ROFS2
- moved a lot of stuff to CORE/ROFS1
- cleaned uda of unneeded language files
- moved UDA to ROFS2
- included Delight MiniCMD
- included Delight App
- FP2 avkon2.mif by mahindar (some more modern system icons)
- PtiEngine mod (ShortMultiTap + removed popup fader by default - changeable in Delight app)
- added new installserver.exe with log by CODeRUS
- WebbrowserFix by hqnqvn
- SIP VOIP extended settings
- Integrated ROMPatcher 3.1 (incl. Domainsrv autostart)
- Modded autostart (removed system apps), added ROMPatcher
- Full close system apps
- Added useful ROMPatches
- ID3 and EQ editor mods
- added ported Anna and S^3 screensavers (Animation, Slideshow and Music Player)
- Anna soundparameters and more volume
- Tactile feedback while calls (removable, check delight FAQ in Additional Files folder)
- Delight animation and sound in C:\data\Animations\, you can replace/remove it
- Use startup.mif/.mp3 and shutdown.gif/.mp3 and enable warning sound in active profile.
- Unlocked menu (create subfolders and rename apps)
- Akncapserver mod
- No USB popups
- Fast theme switcher
- Reduced QtQuick popupfader
- No Ovi signup/SMS
- FP1/2 taskmanager
- Symbols in powerbuttons
- Filemanager extender mod
- Smilies across all applications
- Predic on E
- Swipolicity mod (more rights)
- Heapsize and Closing delay mod
- Camera mod (compression set to 95%)
- No active diverts
- Music folder search in E:\music\ and F:\music\
- Skip E:\effects\ in Gallery
- Music Player Heapsize 30MB
- Infinite Browser cache on D:\
- Voice Recorder mod (5 hours max, 256kbit/s)
- Sysap.exe 3.0 by CODeRUS (restart via power menu, disabled all popups)
- No lock/unlock vibration
- Unlimited SMS sending retries
- Send protected files
- Java permissons mod
- extended maxiumum SMS length to maximum
- added Slippery Scrolling mod (you can change it by Delight app)
- modified CPU and GPU config (for best battery time)
- Renaming profile mod
- Fixed chinese and taiwan chinese - with working pronunction dictionary
- fixed arabic handwriting (for handwriting in latin, you can install the arabic rofs3)
- Show hidden apps
- 22 Equalizer sets added by viral
- X-Plore default language set to english
- Erased pre-set feeds
- Added Delight Blog posts feed & Delight Blog comments feed
- increased maximum MMS size
- profile symbols
- X-Plore more rights mod
- updated menumatrix to show Unit converter in Organiser / GPS Info in Navigation
- deleted Weather widget and all resources
- Email widget Delight style font white
- Note widget Delight style font white
- by Allstar12345
- latest Delight Theme made by LAO STIA
- Transbelle Lighthouse Theme made by MMMOOO and aamirx64
- Delight conversation skin by Cahjoss
it replaces the default conversation skin in messages. Use the Delight App to change skins on-the-fly
- Nokia Pure Font
- SMS Themer app (Delight exclusive)
- added Unit converter app from s60v5
- added Gps Info app from s60v5
- Connectivity Analyzer
- WebSearch Ultimate Lite
- Internet Radio
- WinRar v1.01
- X-Plore v1.6 (with custom settings and icon by BelleXDesigns)
Added DelightApp:
- latest Delight app build
- latest MiniCMD version
- one QML UI for all Delight exclusive apps + new features
- FAQs (Delight FAQ & Backup&Restore FAQ)
- Help
- latest CFW changelogs
Widgets Added:
- Note widget small as extra widget, thanks Robo3737
- Webview widget small 4*3 by huellif
- Anna email widget (1 line) by Robo3737
- single Contact communication widget
- Webview widget
- Stopwatch widget
- Anna Notifications (incl. Belle Icons)
- Anna Notifications 2*2
- Calendar small
- Clocks: analogue – small, profile, small digital, text small
- Contacts: mini, comms
- Small: DLNA server, WIFI
- Internet Radio
- Mail One Line
- Music player, compact
- Search and Search Mini in ROFS
- Vertu Apps Launcher
Skins from:
Kang Shao
You can replace all skins which are in C:\resource\apps with your own (without wasting RAM via joshlog/iChris patch).
To restore default/delight skins check Delight resolver documentation.
Some widgets need joshlog or flashing: all email, all contacts and bookmarks widget.
- DLNA capability
- By default one empty homescreen with Delight wallpaper, max. 10
- Disabled product improvment
- Disabled screensaver
- Delight menu, A-Z order
- Disabled charging notes
- Light time-out 600 seconds
- Screen/keylock time-out 10 minutes
- Disabled FOTA cache
- Dialer & FM landscape
Applications Removed:
- Nokia Music
- F-Secure
- YouTube
- World Traveler
- Vlingo
- Social
- MS Communicator
- Shazam
- Angry Birds
- NatGeo
- Backgrounds
Updates included:
- Message fix
- Email & Calendar Update
- homescreen widgets
- Nokia Store latest release
Known issues:
- you name it
Download links: C6-01 (RM-718) Delight v1.0 Release post at the blog
Please don't reupload/mirror this CFW, this isn't a slow hoster or an adversitment page like
Mod providers:
- Il.Socio - Rompatcher, Nokia Cooker and a lot more.
- CodeRUS - A lots of mods.
- iChris701 - For his mods and help
- iExtraX7 - Several mods.
- Ancelad - Tactile Feedback and few other mods.
- witcher3 - Menu organized
- xCape - Mod and few tips on widgets and a lot other stuff.
- Lovelas - few ported screensaver.
- moki - Fixed font problem.
- Cigiampa/xCape - Script files
- 7b - More Icons in Power Menu
- Stephan020793 - his tutorials were my first step into Symbian modding
- strategist - for his camera mod
- MoritzJT - his help with fonts
- Symbian Fan - for help with product improvment
- Robo3737 - for his widgets
- Skull-ATOS - for screensaver
- Joe3, M4C351, peoresnada - for notifications widget
- RedX - for his legendary cenrep informations
- omkarkul - for his mods
- BelleXDesigns - for X-Plore icon & NEW backup, resolver, restore, updater icons
- aniket - single communication contact widget
- haqanguven - the web browser fix
- Turek - Notification lights ON, Menu Lights OFF mod
- TheOne - Text under HS icons sis - installer/deinstaller
