Nokia 500 - RM-750 DELIGHT CFW v1.1 - všechny jazyky
Příspěvekod freaxs_r_us v stř úno 19, 2014 10:32 am
Update: v1.1
FAQ, Backup and Restore Documentation, Delight Resolver Documentation are in DelightApp integrated.
New exclusive Delight app - the SMS Themer
opens the gallery and you can choose any picture for the messaging background skin
it automatically resizes any picture to 640x640
Changelog since v1.0:
Space: 160mb free on C:
Ram: 100mb
Mods:
- increased maximum MMS size
- profile symbols
- X-Plore more rights mod
Added:
- SMS Themer app (Delight exclusive)
- added Transbelle Lighthouse Theme (z:/)
- added Unit converter app from s60v5
- added Gps Info app from s60v5
Fixes:
- updated menumatrix to show Unit converter in Organiser / GPS Info in Navigation
- Updated to latest MiniCMD version
- removed some double files, entries and unneeded folders
- fixed SMS bug of Delight App skin location changer
- fixed semi-transparent favourite contacts widget
- deleted Weather widget and all resources
- Email widget Delight style
- Email widget Delight style font white
- Note widget Delight style font white
- fixed first boot screen
Updates:
- updated Delight App to 1.2.2
- updated Delight Theme
Effects:
- updated and fixed, thanks to Allstar12345
How to update?
a) if you flashed v1.0
- flash via "Update Software" and without UDA
- after flashing run the app updater will start, select v1.1 and let it do it's job
b) you didn't flash v1.0 before:
you have to flash the whole CFW via Refurbish.
Download: via Delight blog
Links for additional files, documentation, deleted sounds and ROFS3 versions are also on our blog.
Have fun and please share feedback Wink
freaxs_r_us
