Nokia 700 - RM-670 - DELIGHT CFW v1.1 - všechny jazyky
Příspěvekod freaxs_r_us v stř úno 19, 2014 10:33 am
700 Delight v1.1
FAQ, Backup and Restore Documentation, Delight Resolver Documentation are in the Delight APP on the firmware and HERE
Delight team:
- huellif - main developer & cooker
- freaxs_r_us - translator & cooker
Special thanks goes to nicesoni_ash, for his help, knowledge and support.
This CFW has been created with NokiaCooker. Consider donating for Free and High Quality softwares.
http://www.symbian-toys.com/NokiaCooker.aspx
IF YOU WANT TO RELEASE THIS TO A FORUM OR BLOG YOU KNOW,
THEN PLEASE ONLY WITH OUR DIRECT LINKS
please don't forget to share us, like us, twitter us & follow us on the blog
Read FAQ Provided with flashing files and then ask other questions.
THESE FILES ARE RE-PARTITIONISED!!! DO NOT MIX WITH OTHER FIRMWARES!!!
Supporters:
- Allstar12345 - theme effects maker
- LAO STIA - theme maker
- Cahjoss - Delight Conversation skin
- Mahindar - widget mifs maker / fixer
Link your post to our blog for files and changelogs if you want to post it somewhere else
Note:
This is a completly new CFW, based on Belle FP2 113.010.1506, product code
059G1Z6
cooked by huellif and freaxs_r_us
Special's in this CFW:
After Flashing complete,
your phone will restart once showing you different
notifications. Let it do its work.
After restart, you are all set to go.
What does this mean?
Simple answer, the UDA is empty, all files form UDA are in ROFS and get copied to C:\ after first boot or a hardreset.
- in Menu, Tools, Xtras you will find Delight App, it contains our Backup&Restore solution, FAQs, Changelogs, a Resolver and MiniCMD launcher
**Check Change Log Here**
C:drive after flash is minimum 370mb
RAM: 290mb - 295mb
Changelog:
Fixed:
- Camera fixed
- Videocamera fixed
- Kontakt widgets fixed
- fixed semi transparent favourites widget to non-transparent
- Sysap 1.4 by iChris701, now it will show SSL cert popups like on original firmwares
- fixed increase heap size mod
- fixed Effects
Removed:
- Nokia weather widget and weather resources
Added:
- exclusive keyboard skin by bhavin192 (you can revert to original one via Delight App)
- Photo Editor from N8 (you still can access FP2 editor from gallery)
- Video Editor from N8 (you still can access FP2 editor from gallery)
- Unit Converter from s60v5
- GPS Info app from s60v5
- Delight SMS Themer)
- Remove recording tone patch
- Evenfasterkeylockevent patch
Mods:
- added full filesystem read access to X-Plore and full write access of :\private\
- Picture viewer works in :\private\ folders
- increased maximum MMS size
Updated:
- Menumatrix to show Unit Converter in Organiser & GPS Info in Navigation
- Updated Delight App to 1.3.0
Themes:
- Transbelle Lighthouse Theme
- Delight theme updated
- Evolve Theme modded for GPS Info icon change
- added "Evolve Qt 3.0 For FP2" theme by SLAYER33
Widget skins: new by Mahindar
- Dlan big & small
- Wlan small
- VPN toggle
- Operator
- Stopwatch
Effects
- Smooth As Hell V4 by Allstar12345
Known issues:
- you tell me
Delight App v1.3.0
Added:
- manual scrolling settings to Selector
- manual light settings to Selector
- FM Transmitter RDS tag chooser to Selector
- FP2 keyboard skin Selector
- Credtis page
Other:
- performance improvments
- some fixes
- rearenged code
- browser fixer is working on the fly
Download & Translations
At the BLOG
Please don't reupload/mirror this CFW, this isn't a slow hoster or an adversitment page like adf.ly
Translations & Info
Instructions:
Notice: only english version has all files needed
1. Just get the download from the blog
2. get the translated rofs2 = Ui translation from me if desired
3. exchange the rofs2 you got from me with the one in the full cfw set
4. get a writing file rofs3 if you need additional writing files
(the rofs2 translations has the chosen writing files)
5. exchange the rofs3 you got from me with the one in the full cfw set
Translation features:
- ALL needed standard files in your language (if provided by Nokia)
- ALL needed modded files that need translating to work
- IF TTS (text to speech) is available in your language, then it is included
- ALL translations have english as base files
- all writing and keyboard files
- all dialer files
- added ecom-3-0.spi which can handle ALL languages
- translated all new widgets and corrected old ones (I corrected over 500 strings)
- text clock widgets in your language; translations by wirer
for now only 02, 03, 04, 17, 18, 25, 27, 42, 54, 68, 76, 79 ... maybe more later
Known "Issues":
- Third party Applications, for example: ROM patcher+, are not translated
- in more than 1 language packages there will be only english text clock
- metadatamod equalizer mod in english
- rarely used languages, such as galician, basque, canadian french, chinglish & taiwan english are not made
Credits:
Delight testers:
- Peter H
Thanks for your help :)
Mod providers:
- Il.Socio - Rompatcher, Nokia Cooker and a lot more.
- CodeRUS - A lots of mods.
- iChris701 - For his mods and help
- iExtraX7 - Several mods.
- Ancelad - Tactile Feedback and few other mods.
- witcher3 - Menu organized
- xCape - Mod and few tips on widgets and a lot other stuff.
- Lovelas - few ported screensaver.
- moki - Fixed font problem.
- Cigiampa/xCape - Script files
- 7b - More Icons in Power Menu
- Stephan020793 - his tutorials were my first step into Symbian modding
- strategist - for his camera mod
- MoritzJT - his help with fonts
- Symbian Fan - for help with product improvment
- Robo3737 - for his widgets
- Skull-ATOS - for screensaver
- Joe3, M4C351, peoresnada - for notifications widget
- RedX - for his legendary cenrep informations
- omkarkul - for his mods
- BelleXDesigns - for X-Plore icon & NEW backup, resolver, restore, updater icons
- aniket - single communication contact widget
- haqanguven - the web browser fix
- Turek - Notification lights ON, Menu Lights OFF mod
- TheOne - Text under HS icons sis - installer/deinstaller
and everyone who helped me in one way or another..
Let me know if I missed something and I would add your name in here. Thanks.
Hope you enjoy this version too.. :D
Post your views, suggestions or any bug report... Thanks.
Kindly
read FAQ file for your troubles and if you don't get the answer of your
problems in there, than only put your question here.
if you want to know whats going on first hand...follow us
by adding your email to this on the right hand side of the blog:
and recieve emails as soon as something changes
help us helping you
the more followers we have the better for the blog
And don't forget to "like" us on facebook
"share" us on google
and anything else you use
Delight 700 v1.1 blog post
freaxs_r_us
Příspěvekod Stybyk v ned bře 01, 2015 3:57 pm
I can´t download it, file :( is not exist :( Please can you upload it again ?
Stybyk
Model telefonu: Nokia 700
