Nokia E7 - RM-626- Delight CFW v1.0 - všechny jazyky
Příspěvekod freaxs_r_us v stř úno 19, 2014 10:36 am
Release v1.0
FAQ, Backup and Restore Documentation, Delight Resolver Documentation are in DelightApp integrated.
New exclusive Delight app - the SMS Themer
opens the gallery and you can choose any picture for the messaging background skin
it automatically resizes any picture to 640x640
Changelog :
C:\ drive after flash is minimum 372 MB
RAM: 142 MB
Mods:
    [li]- all Delight flashing file settings:
    - extended CORE/ROFS1
    - unlocked CORE
    - cleaned CORE
    - changed purpose and sw text
    - cleaned ROFS2
    - moved a lot of stuff to CORE/ROFS1
    - cleaned uda of unneeded language files
    - moved UDA to ROFS2
    - included Delight MiniCMD
    - included Delight App
    - FP2 avkon2.mif by mahindar (some more modern system icons)
    - PtiEngine mod (ShortMultiTap + removed popup fader by default - changeable in Delight app)
    - added new installserver.exe with log by CODeRUS
    - WebbrowserFix by hqnqvn
    - SIP VOIP extended settings
    - Integrated ROMPatcher 3.1 (incl. Domainsrv autostart)
    - Modded autostart (removed system apps), added ROMPatcher
    - Full close system apps
    - Added useful ROMPatches (deleted those not needed in Nokia 500)
    - ID3 and EQ editor mods
    - added ported Anna and S^3 screensavers (Animation, Slideshow and Music Player)
    - Anna soundparameters and more volume
    - Tactile feedback while calls (removable, check delight FAQ in Additional Files folder)
    - Delight animation and sound in C:\data\Animations\, you can replace/remove it
    - Use startup.mif/.mp3 and shutdown.gif/.mp3 and enable warning sound in active profile.
    - Unlocked menu (create subfolders and rename apps)
    - Akncapserver mod
    - No USB popups
    - Fast theme switcher
    - Reduced QtQuick popupfader
    - No Ovi signup/SMS
    - FP1/2 taskmanager
    - Symbols in powerbuttons
    - Filemanager extender mod
    - Smilies across all applications
    - Predic on E
    - Swipolicity mod (more rights)
    - Heapsize and Closing delay mod
    - Camera mod (compression set to 95%)
    - No active diverts
    - Music folder search in E:\music\ and F:\music\
    - Skip E:\effects\ in Gallery
    - Music Player Heapsize 30MB
    - Infinite Browser cache on D:\
    - Voice Recorder mod (5 hours max, 256kbit/s)
    - Sysap.exe 3.0 by CODeRUS (restart via power menu, disabled all popups)
    - No lock/unlock vibration
    - Unlimited SMS sending retries
    - Send protected files
    - Java permissons mod
    - extended maxiumum SMS length to maximum
    - added Slippery Scrolling mod (you can remove it via deleting C:\private\10202be9\persits\20021192.cre
    - modified CPU and GPU config (for best battery time)
    - Renaming profile mod
    - Fixed chinese and taiwan chinese - with working pronunction dictionary
    - fixed arabic handwriting (for handwriting in latin, you can install the arabic rofs3)
    - Show hidden apps
    - 22 Equalizer sets added by viral
    - X-Plore default language set to english
    - Erased pre-set feeds
    - Added Delight Blog posts feed & Delight Blog comments feed
    - increased maximum MMS size
    - profile symbols
    - X-Plore more rights mod
    - updated menumatrix to show Unit converter in Organiser / GPS Info in Navigation
    - deleted Weather widget and all resources
    - Email widget Delight style font white
    - Note widget Delight style font white[/li]
Effects:
    [li]- by Allstar12345[/li]
Added:
    [li]- latest Delight Theme made by LAO STIA
    - Transbelle Lighthouse Theme made by MMMOOO and aamirx64
    - Delight conversation skin by Cahjoss
    it replaces the default conversation skin in messages. Use the Delight App to change skins on-the-fly
    - Nokia Pure Font[/li]
Apps:
    [li]- SMS Themer app (Delight exclusive)
    - added Unit converter app from s60v5
    - added Gps Info app from s60v5
    - Connectivity Analyzer
    - WebSearch Ultimate Lite
    - Internet Radio
    - WinRar v1.01
    - X-Plore v1.6 (with custom settings and icon by BelleXDesigns)
    [/li]
Added DelightApp:
    [li]- latest Delight app build
    - latest MiniCMD version
    - one QML UI for all Delight exclusive apps + new features
    - FAQs (Delight FAQ & Backup&Restore FAQ)
    - Help
    - latest CFW changelogs
    [/li]
Widgets Added:
    [li]- Note widget small as extra widget, thanks Robo3737
    - Webview widget small 4*3 by huellif
    - Anna email widget (1 line) by Robo3737
    - single Contact communication widget
    - Webview widget
    - Stopwatch widget
    - Anna Notifications (incl. Belle Icons)
    - Anna Notifications 2*2
    - Calendar small
    - Clocks: analogue – small, profile, small digital, text small
    - Contacts: mini, comms
    - Small: DLNA server, WIFI
    - Internet Radio
    - Mail One Line
    - Music player, compact
    - Search and Search Mini in ROFS
    - Vertu Apps Launcher[/li]
Skins from:
    [li]Rudmata
    Xinox
    Kang Shao
    SelvaSathyam[/li]
You can replace all skins which are in C:\resource\apps with your own (without wasting RAM via joshlog/iChris patch).
To restore default/delight skins check Delight resolver documentation.
Some widgets need joshlog or flashing: all email, all contacts and bookmarks widget.
Ported:
    [li]- DLNA capability[/li]
Configurations:
    [li]- By default one empty homescreen with Delight wallpaper, max. 10
    - Disabled product improvment
    - Disabled screensaver
    - Delight menu, A-Z order
    - Disabled charging notes
    - Light time-out 600 seconds
    - Screen/keylock time-out 10 minutes
    - Disabled FOTA cache
    - Dialer & FM landscape[/li]
Applications Removed:
    [li]- Nokia Music
    - F-Secure
    - YouTube
    - World Traveler
    - Vlingo
    - Social
    - MS Communicator
    - Shazam
    - CNN
    - Angry Birds
    - NatGeo
    - Backgrounds[/li]
Updates included:
    [li]- Message fix
    - Email & Calendar Update
    - homescreen widgets
    - Nokia Store latest release
    [/li]
Known issues:
    [li]- you name it
    [/li]
How to update?
    [li]
    Since this is the first build:
    you have to flash the whole CFW via Refurbish.
    [/li]
SPECIAL E7 Instructions:
1. Download the E7 base files and extract to folder
2. get the translated Ui file (rofs2) from below - english needs to be downloaded as well!
- insert the Ui language rofs2 to your flashing files
- translated versions have english as well
3. get the hardware keyboard and virtual keyboard files rofs3 according to your device and language
- I can not disclude virtual keyboards of original languages
- I can include any virtual keyboard you need - but only on request (I am not going to make 800 - 1000 rofs3's by chance)
- IF you want a extra virtual keyboard language, then the hardware keyboard will be temporarily miss-set as long as the language that is not in original firmware is chosen as input language
Info: there are something like 40 -55 hardware keyboard writing files. depending on:
- which languages are in the original firmware
- hardware keyboard letter differences
- hardware keyboard symbols on buttons differences
IF you have problems due to the hardware keyboard rofs3, like missplaced letters or missplaced symbols on buttons: DON'T PANIC!!!
- just send me your product code and I will make a new hardware keyboard rofs3 a.s.a.p.
• 29 taiwan chinese - Taiwan chinese worldwide exclusive language NEVER provided by Nokia
for Taiwan Users that bought a E7 from other countries
be sure to get the correct hardware keyboard files
E7 exclusive slidewizard file was implemented from r31 chinese to r29 taiwanese
• 57 hebrew - Hebrew worldwide exclusive language NEVER provided by Nokia
for Hebrew Users that bought a E7 from other countries
E7 exclusive slidewizard file was implemented from r01 english to r57 hebrew
Virtual Keyboard & Hardware Keyboard Writing files sets: (ROFS3's)
(don't pay too much attention to the keymapping file numbers. they are an info for me mostly.
just keep in mind which keyboard you have and which languages you want
if you flash a not compatible one, then your letters and symbols will be missplaced. if so, don't panic,
just flash again via software update without uda)
• Euro 1 QW & english, french, german, dutch, romanian - keymapping 01
• Scandinavia QW1 & english, swedish, finnish - keymapping 02
• Scandinavia QW2 & english, danish, norwegian, icelandic - keymapping 03
• German QWERTZ & english, french, german, italian, turkish - keymapping 04
• Austrian QW1 QWERTZ & english, french, german, italian, turkish - keymapping 05
• Switzerland QW2 & english, french, german, italian, turkish - keymapping 06
• Turkey QW3 & english, french, german, italian, turkish - keymapping 07
• French AZERTY & english, french, german, dutch - keymapping 08
• Euro 2 QW1 & english, french, german, spanish, italian, portugese - keymapping 09
• Euro 2 QW2 & english, french, german spanish, italian, portugese - keymapping 10
• Spanish QW & english, spanish, portuguese, catalan, basque, galician - keymapping 11
• Balkans QW1 & english, german, slovenian, croatian, serbian - keymapping 12
• Balkans QW2 & english, german, slovenian, croatian, serbian - keymapping 13
• Euro 3 QW1 & english, german, hungarian, czech, slowak, polish - keymapping 15
• Euro 3 QW2 & english, german, hungarian, czech, slowak, polish - keymapping 16
• Euro 3 QW3 & english, german, hungarian, czech, slowak, polish - keymapping 17
• Greek QW & english, greek - keymapping 18
• Hungarian QW1 & english, hungarian, romanian - keymapping 19
• Hungarian QW2 & english, russian, hungarian, romanian - keymapping 20
• Russian QW1 & english, russian, romanian, ukrainian - keymapping 21
• Russian QW3 & english, russian, kazakh, romanian, ukrainian - keymapping 23
• Baltian QW1 & english, german, russian, estonian, latvian, lithuanian - keymapping 24
• Baltian QW2 & english, german, russian, estonian, latvian, lithuanian - keymapping 25
• Bulgarian QW & english, french, german, dutch, bulgarian, romanian - keymapping 27
• MEA A ArabicQWERTY & english, french, portuguese, arabic - keymapping 28
• MEA A LatinAZERTY & english, french, portugese, arabic - keymapping 29
• MEA C ArabicQWERTY & english, arabic, farsi, urdu - keymapping 32
• MEA I LatinQWERTY & english, french, german, spanish, italian, portuguese - keymapping 33
• MEA I PortugeseQWERTY & english, french, german, spanish, italian, portuguese - keymapping 34
• MEA I LatinAZERTY & english, french, german, spanish, italian, portuguese - keymapping 35
• APAC QW1 - english, chinese, chinese english, malaysian, indonesian - keymapping 36
• APAC QW2 - english, tagalog - keymapping 37
• Vietnam QW & english, vietnamese - keymapping 38
• Thai QW & english, thai, thai english - keymapping 39
• India QW & english - keymapping 41
• China QW & english, chinese english, chinese - keymapping 48
• NAM QW1 & english, american englisch, canadian french, brazilian portuguese, latin-american-spanish - keymapping 51
• LTA QW2 & english, french, american english, dutch, brazilian portugese, latin-american-spanish - keymapping 52
• Brazil QW3 & english, french, american english, portugese, brazilian portugese, latin-american-spanish - keymapping 53
Download: via Delight blog
Links for additional files, documentation, deleted sounds and ROFS3 versions are also on our blog.
Have fun and please share feedback ;)
freaxs_r_us
