Nokia C7 - RM 675 - Delight CFW v6.4 - všechny jazyky
Příspěvekod freaxs_r_us v stř úno 19, 2014 10:39 am
Update: v6.4
FAQ, Backup and Restore Documentation, Delight Resolver Documentation are in DelightApp integrated.
New exclusive Delight app - the SMS Themer
opens the gallery and you can choose any picture for the messaging background skin
it automatically resizes any picture to 640x640
Changelog from v6.3:
    - increased maximum MMS size
    - profile symbols
    - torch mod, now you can enable torch via lock key in power saver mode
    - EvenFaster patch for ROMPatcher
    - X-Plore more rights mod
    - new Applauncher widget mif
    - new operator widget mif[/li]
    - SMS Themer app (Delight exclusive)
    - added Transbelle Lighthouse Theme (Z:\)
    - added Unit converter app from s60v5
    - added GPS Info app from s60v5
    - updated menumatrix to show Unit converter in Organiser / GPS Info in Navigation
    - Updated to latest MiniCMD version
    - removed some double files, entries and unneeded folders
    - moved a lot of folders and files to ROFS1
    - fixed SMS bug of Delight App skin location changer
    - fixed semi-transparent favourite contacts widget
    - deleted Weather widget and all resources
    - Email widget Delight style font white
    - Note widget Delight style font white
    - ROFS2 smaller of 7MB / rofs3 bigger 7MB - Firmware still update-able - OLD FILES NOT COMPATIBLE ANYMORE
    - added writing files ROFS3's like in other Delights for optional writing files
    - updated Delight App to 1.2.2
    - updated Delight Theme
    - updated and fixed, thanks to Allstar12345
How to update?
    a) if you flashed v6.0/6.099/v6.2/v6.3:
    - flash via "Update Software" and without UDA
    - after flashing run the app updater will start, select v6.3 and let it do it's job
    b) you didn't flash v6.0/v6.099/v6.2/v6.3 before:
    you have to flash the whole CFW via Refurbish.
Download: via Delight blog
Links for additional files, documentation, deleted sounds and ROFS3 versions are also on our blog.
Have fun and please share feedback ;)
