New Symbian Hack without PC by CODeRUS
Příspěvekod pyler v stř zář 21, 2011 5:23 pm
New Symbian Hack without PC. Vivaz too
First of all thanks Kevin (Evilhawk00) for info about UMU quarantine.
And of course thanks UMU for unsafe quarantine in UMU Mobile Security =)
Let's go!
1. install UMU*Hack.sisx. After installing application will be launched.
2. Accept connection ask (you can use WiFi)
3. Accept trial key
4. Accept license
5. Select Yes
6. Select No, then OK
7. Select Ok - Enter 123 - Retype 123
8. Press Options - Anti-Virus
9. Go to Quarantine
10. Options - Restore - Press Yes
11. Back - Home - Exit - Uninstall UMU Mobile Security
12. Enter 123 password for uninstallation
13. Install RomPatcherPlus_3.1.sisx - Launch it - Apply Open4all - You get full access to all folders
14. Apply installserver (if red cross - found in web installserver for your phone) - You can install any applications without signing.
Enjoy =)
NOKIA:
https://sites.google.com/site/icoderus/UMUNokiaHack.sisx
Sony Ericcson:
https://sites.google.com/site/icoderus/UMUSonyEricssonHack.sisx
RomPatcher+:
https://sites.google.com/site/icoderus/RomPatcherPlus_3.1.sisx
Zdroj:
http://symbian-coderus.blogspot.com/2011/09/new-symbian-hack-without-pc-vivaz-too.html
Re: New Symbian Hack without PC by CODeRUS [21.9.2011]
Příspěvekod Rusnak-COBRA v stř zář 21, 2011 5:54 pm
Hack all Symbian telefonov by CODeRUS pomocou antiviru UMU Mobile Security
THX to Pyler, donasacovi noviniek ;)
Aj VIVAZ a SATIO od Sony Ericssonu!!!
Postup:
1. Nainstalujte UMU***Hack.sisx. (Podla znacky mobilu. Po instalacii sa aplikacia spusti.)
2. Potvrdte otazku o pripojeni. (Radsej pouzite Wi-Fi)
3. Akceptujte trial kluc
4. Akceptujte licenciu
5. Zvolte Yes
6. Zvolte No, potom OK
7. Zvolte OK - zadajte 123 - znovu zadajte 123
8. Stlacte Options >>> Anti-Virus
9. Zvolte Quarantine
10. Options >>> Restore - stlacte Yes
11. Back >>> Home >>> Exit (Mozete odinstalovat UMU Mobile Security)
12. Zadajte kod 123 pri odinstalacii
13. Nainstalujte prilozeny RomPatcherPlus_3.1.sisx - spustite ho - aktivujte Open4all (to Vam da plny pristup do systemu)
14. Aktivujte Installserver patch (ak je cerveny, najdite si installserver.exe pre Vas teelefon a nakopirujte do C:\sys\bin)
Huraaa, hack je hotovy. Enjoy ;)
Testovane na C7 (Anna), Vivaz, E72...
UMU.4shared.com
Rusnak-COBRA
Potrebujete pomoc? Ozvite sa kde ma najdete :D
Symbian & MeeGo fan, skor cestny funkcionar par for vratane Nokioteca
ZBIERAM MOBILY - stare, rozbite a pokazene... POTESTE MA AJ VY ;)
zbierka cez 880ks
Rusnak-COBRA
Model telefonu: Jolla, BB Z10, N950, N9, Peak
Příspěvekod maslo79 v sob zář 24, 2011 9:00 pm
SUPER funguje to na 100 percent DAKUJEM velmi pekne
:class: :class: :class: :class:
maslo79
Model telefonu: SE Vivaz PRO
Příspěvekod hanni v ned zář 25, 2011 9:22 pm
Testnuté na kolegovej E52 s posledným FW, úplne bez problémov :class:
Příspěvekod Adalbert72 v stř zář 28, 2011 7:02 pm
Je skvělé, že na nás CODeRUS nezapomněl, takže si asi přece jen koupím od soudruhů z Finska ještě nějaký tel. Předpokládám, že tohle bude efektivnější metoda než IAL Hack, nebo jsou pro něj ještě nějaké důvody?
2x N8-00 Dark Grey, v.111.040.1511 Belle Refresh h@cked
Adalbert72
Model telefonu: N8-00
Příspěvekod Rusnak-COBRA v stř zář 28, 2011 8:03 pm
je to spravene len inym antivirom, to je cele, no vyhoda je v tom ze nemusis pouzit PC. ale za to musis pouzit internet na "aktivaciu" trial verzie. takze za mna - radsej IAL :)
tento hack ale coderus nevymyslel, metodu ma na svdomi IAL, napad pouzit iny antivirak uz nebol tak originalny, nemyslis? :)
Rusnak-COBRA
zbierka cez 880ks
Rusnak-COBRA
Příspěvekod pyler v čtv zář 29, 2011 5:16 am
ale vytvorit subor karanteny je tiez zlozite,najma co som kukal tento v UMU hacku ...
Příspěvekod Izic v pon říj 03, 2011 5:51 pm
Nevím co dělám špatně, ale už jsem zkoušel tento hack 5x a stále nejde dokonce jsem i přehrál software telefonu a stále nic :help: :t pořád háže hlášky ohledně certifikátů a nemám přístup do všech složek (zobrazují se v PC nebo v telefonu ? ) .. Mám Vivaz U5i
Izic
Příspěvekod pyler v pon říj 03, 2011 5:55 pm
precitaj si navod este 10x ..
ake hlasky ti hadze ? Urobil si restore suboru v tom antivire ? ...
Boze,ved je to strasne easy len si netreba vymyslat novy navod ...
Příspěvekod Izic v pon říj 03, 2011 6:06 pm
přečetl jsem si už xkrát už ho znám nazpamět přísahám, když chci např nainstalovat slideunlock tak mi po to po vybrání cílové složky vyhodí hlášku limited by cert..
Izic
Příspěvekod pyler v pon říj 03, 2011 6:39 pm
a aktivoval si patche v ROMPatcheri ? Stiahni ich tu (patches.4shared.com) a oba patche daj do e:/patches,spust rp+,daj options-all patches-apply ,pre autostart patchov daj este options-add to auto ....
Příspěvekod Rusnak-COBRA v pon říj 03, 2011 7:47 pm
a samozrejme instaluje necertifikovane aplikacie.
Rusnak-COBRA
zbierka cez 880ks
Rusnak-COBRA
Příspěvekod Izic v úte říj 04, 2011 2:37 pm
pyler píše:a aktivoval si patche v ROMPatcheri ? Stiahni ich tu (patches.4shared.com) a oba patche daj do e:/patches,spust rp+,daj options-all patches-apply ,pre autostart patchov daj este options-add to auto ....
Dnes jsem vytvořil složku patches na pamětovce přes mobil a naházel jsem tam ty patche jak jsi mi poradil ale pořád nefunguje. Pak jsem dále zkoušel nainstalovat znovu rom patcher na pamětovou kartu, ale to taky nepomohlo.. :t
Izic
Příspěvekod pyler v úte říj 04, 2011 3:09 pm
co presne nefunguje ? Ved rp+ sa ti spusti,nie ? Tak tie patche aktivuj ..
Příspěvekod Izic v úte říj 04, 2011 3:32 pm
všechno se mi spustí, vše aktivuju, ale nemám možnost se podívat do všech složek a instalačky mi též nejdou..
Izic
Příspěvekod pyler v úte říj 04, 2011 3:53 pm
a patche mas v rp+ zelene ?
Příspěvekod Rusnak-COBRA v úte říj 04, 2011 5:11 pm
a hlavne, cez co sa do systemovych zloziek pozeras?? v xplore mas zakliknute skryte a systemove?
Rusnak-COBRA
zbierka cez 880ks
Rusnak-COBRA
Příspěvekod Izic v stř říj 05, 2011 5:22 pm
Tak ted jsem si stáhl Xplore a už vidím c:/sys ale stále nemůžu instalovat aplikace :/ přes co je instalujete vy normálně přes základní instalátor mobilu nebo je něco jiného na instalace ?
Izic
Příspěvekod pyler v stř říj 05, 2011 5:33 pm
vloz installserver.exe (z prilohy) do C:/sys/bin ;)
http://upwap.ru/1758372
Příspěvekod Izic v stř říj 05, 2011 6:05 pm
Hodil jsem to tam ale stále limited by certificate... hlavně že v x-ploru vidím uplně vše ale pořád nemužu nic nainstalovat.. už je to fakt absurdní
vasikk\\
Necituj poslední příspěvky. Koukni na pravidla :tyty:
Naposledy upravil vasikk dne stř říj 05, 2011 8:23 pm, celkově upraveno 1
Důvod: citace...
Izic
Příspěvekod pyler v stř říj 05, 2011 6:11 pm
a to co skusas instalovat je UNSIGNED (nepodpisane) ? skus nainstalovat nieco ine (napr. toto,nepodpisuj to nijakym certifikatom,len nainstaluj!)
p.s: uz mi pis radsej SZ,nech to tu nezaspamujeme :-D
Příspěvekod Izic v pát říj 07, 2011 1:33 pm
no nainstaloval jsem to.. k čemu to je ?
Izic
Příspěvekod pyler v pát říj 07, 2011 2:54 pm
to je jedno,je to unsigned apl.,cize MOZES instalovat unsigned apl. ...
dovi ...
Příspěvekod gemarc v pon říj 10, 2011 6:49 pm
Hmm. Divné. Vše proběhlo bez problémů, C:/sys/bin mám přístupný a installserver.exe pro E51 v něm, ale stejně nic nenainstaluji :(
Edit: tak zpět, nepodepsané opravdu jdou. Zkoušel jsem omylem ocertifikované na jiný tlf.
E71 a na zkoušku Vivaz Pro
gemarc
Příspěvekod Hepaa v čtv říj 13, 2011 2:57 pm
Hack přes UMU jsem úspěšně dělal na mojí E52, ale nějak se mi nedaří zprovoznit ho na druhém telefonu - Vivaz.
Vše jde podle návodu, ale zaseknu se u RomPatcheru. Když instaluju LITE verzi, tak po spuštění mi hlásí chybu \sys\bin\Patcher*LDD Not Found! a tudíž nezapnu ani jeden z patchů. Klasickou 3.1 nenainstaluju kvůli chybě certifikátu.
Hepaa
Model telefonu: Nokia E52 • 033.002 • HACKED
Příspěvekod pyler v čtv říj 13, 2011 3:42 pm
znovu restorni karantenne subory v UMU antivire ...
Příspěvekod maslo79 v úte lis 15, 2011 6:11 pm
Rusnak-COBRA
prosim ta mne to stale pise aby som vlozil kluc ze tiral verzia uz skoncila nevies mi poradit co s tym mam vivaz pro dik za odpoved
maslo79
Příspěvekod petrnav v úte lis 22, 2011 9:09 pm
Před měsícem na N97 mini hack bez problémů,teď na N8 píše,že skončila platnost trial verze,tak jsme asi dohackovali,ale rád bych se pletl.Nevíte někdo co s tím?Děkuji za odpověď.
petrnav
Model telefonu: N95
Příspěvekod Turek v úte lis 22, 2011 9:20 pm
Testni norton hack ? Ten jsem na n8 dělal a úspěšně ;)
Příspěvekod petrnav v stř lis 23, 2011 6:18 am
Thank you.Funguje super.
Turek // jsem rád, že funguje. Necituj poslední příspěvek viz. pravidla fóra.
Naposledy upravil Turek dne stř lis 23, 2011 6:47 am, celkově upraveno 1
Důvod: Odstraněna citace.
petrnav
Model telefonu: N95
