Nokia E52 jen zavibruje po stisknuti zap. tl.
Příspěvekod Syssx v čtv pro 01, 2011 3:51 pm
Zdravím,
Mám takový problém ...
Aktualioval jsem svoji E52 přes FOTA na 081.003 a hned na to jsem začal hrát jednu hru (GoldMiner) a telefon se seknul a restartnul se . Tak jsem si řekl OK tohle dělá často a zapnul jsem si 3gp video (scary movie) a hned potom se telefon freeznul a nerestartoval se sám tak jsem jako vždy vyndal baterku a chtěl ho zapnout ale nic se nestalo jenom zavrněl ...po pár pokusech a vyndání baterky na cca 5min se zapnul a hned potom zase freez a všechno znova a toď vše. Tak jsem se rozhodnul že ho flašnu přes Phoenix (dead usb) a takhle to dopadlo :
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
--- Press phone's power button! ---
Loading secondary boot code: 15168 bytes
Secondary boot loaded
Loading update server code: 722517 bytes
Update server loaded
Partitioning....
Partitioning complete
Erasing....
Erasing complete
Asic CMT: Start programming 172706 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Programming complete
WARNING:  Asic CMT: NAND status reported bad blocks
Asic CMT: programming succeeded
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Starting to recover the phone
Recoverying phone
Initializing
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
ERROR: Unable to detect device 0x8401F145. Check USB connection!
ERROR: Product recovery failed!
Unable to set the phone to flash mode. Unable to flash.
Recoverying phone
Initializing
Recoverying phone
Initializing
Phone recovery completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Failed to verfy communication to product
Hned potom vyskočilo okno :
Flashing finalization failed. Do you like to retry the finalizing?
HRESULT 0x8421001c (-2078212068)
Firmware: Cannot verify communication to phone after flashing. Make sure that phone booted up correctly and retry.
A potom:
HRESULT 0x8421001f (-2078212065)
Firmware: Failed to switch phone to correct mode for fartorysettings using USB.
Vidím to už jen na servis ale záruku mě nevemou měnil jsem totiž PC kvůli češtiny ... tak to až jako poslední řešení ...
Díky za odpovědi
Nokia N95 Hacked>>
Nokia E52 (054.003 Hacked [Thanks to forum.n73.eu])
Syssx
Model telefonu: E52 (054.003)
