Theme Graphics Switcher
Příspěvekod bazdesh v čtv dub 01, 2010 8:53 am
Aplikace, která dokáže z jednoho motivu přenést ikony do druhého :) ( Motivy potom nesdílejte, jen pro osobní použití :pray )
V originále:
Theme Graphics Switcher is an application that allows to transfer application and folder icons from one theme to another. To work it needs sis package of a source theme where icons will be taken from and a target sis package where icons from source theme will be transferred to (sis packages for S60 3rd edition and S60 5th edition are supported).
Choose packages of source and target theme, check the icons you would like to copy then click Start to transfer them. "Remove original icons from target theme" checkbox allows to choose how application icons of source and target themes are synchronized. If it is checked all application and folder icons that do not exist in a source theme are being removed from target theme (so that there is no mix of different icon sets). If not, those icons are kept (this mode can be useful when it is needed to complete icon set in target theme with icons from a source theme).
Theme Graphics Switcher saves a backup of target theme (file with a .bak extension) in the same folder where its sis package is stored. Should something go wrong you can always restore an original theme. You don't have to sign a package of target theme before installation on device, Theme Graphics Switcher will do it for you.
Current version of Theme Graphics Switcher allows to transfer application and folder icons only. If you need other functions, please, support the development and make a donation.
Compatibility: Windows XP/2003 Server/Vista/2008 Server/Windows 7
Download:
http://www.symbiandev.cdtools.net/downloads/tmgswitch_110.zip
(časem dodám screeny jak to vypadá, teď na to nějak nemám čas :) )
Loučím se s vámi, bylo mi tu dobře..
RIP, Symbian OS
bazdesh
Model telefonu: Nokia 5320 cfw 06.203
