Garmin BaseCamp, MapInstall a iný software
Příspěvekod karolE51 v pon úno 13, 2012 5:36 pm
Garmin BaseCamp a MapInstall
Po nainštalovaní MapSource do PC si môžete dodatočne nainštalovať tieto dva uvedené programy.
Softvér BaseCamp je vhodnejší pre turistické trasy pričom je plnohodnotnou alternatívou softvéru MapSource vhodného skôr pre automototrasy. Program MapInstall sa vám už nainštaloval do PC pri inštalácii mapy CNE, takže ho zrejme stačí ošetriť pomocou patche. Ale nestane sa vôbec nič ak ho nainštalujete (alebo preinštalujete) a ošetríte pomocou patche. Nižšie sú najnovšie inštalačky BaseCamp a MapInstall s liečivom.
:ld z oficiálnych stránok
MapInstall software version 4.0.3 (October 23, 2012)
http://www8.garmin.com/support/download_details.jsp?id=3291
BaseCamp software version 4.0.5 (November 15, 2012)
http://www8.garmin.com/support/download_details.jsp?id=4435
liečivo:
http://www.ulozto.cz/xDinw3b/data-rar
Staršie verzie:
Basecamp v3.3.3 (05/2012)
Link na hellshare:
http://jdem.cz/upee6
MapInstall v 4.0.1
released date : 10 May 2012
Popis, inštalácia
Notes:
WARNING: This software will not work unless you already own a MapSource product.
This software requires Windows XP SP3 or greater and Windows Media Player 11 or greater (a free download from Microsoft).
Changes made from version 4.0.0 to 4.0.1:
Fixed an issue where MapInstall was writing maps to the wrong location on memory cards.
Fixed an issue where MapInstall would display some maps twice.
Fixed an issue detecting devices with attached memory cards correctly.
Fixed an issue where MapInstall would not detect some pre-programmed maps correctly.
Fixed an issue where map deletion was reported as a failure.
Added various stability improvements.
Installation Instructions:
Download the MapInstall update file into a directory on your hard drive. (i.e., c:\garmin).
Change to the directory in which you downloaded the files, (i.e., c:\garmin), and run the executable file (.exe). Follow the onscreen instructions to complete the MapInstall installation.
http://www.uloz.to/18743238/mapinstall-401-rar
Staršia verzia:
MapInstall v.4 (04/2012)
Link na hellshare:
http://jdem.cz/ukqc5
Staršie verzie:
BaaseCamp 3.3.1 a MapInstall 3.15.0
Link na ulozto:
http://jdem.cz/ujqa5
Takto to vyzerá v Basecamp v3.3.3. Zvolíme si profil (autom, peši, bicyklom...) a naplánujeme alebo hľadáme vhodnú trasu.
No a takto to vyzerá ak si zvolíte 3D zobrazenie:
Vyselektovanie máp v MapInstall 4 (04/2012) fakt nemá chybu:
GmapTool
Homepage:
http://www.anpo.republika.pl/
GmapTool je nástroj pre prácu s mapami Garmin, pomocou neho môžeme napríklad spájať mapy.
Program je free, najnovšia verzia GMapTool 0.8.11 (4.7.2012) je na domácej stránke alebo tu:
Link na ulozto:
http://www.ulozto.cz/xgNYoXz/gmaptoolsetup08011-exe
V nastaveniach tohoto programu zadajte cestu k cgpsmapper.exe (viď nižšie):
cGPSmapper
Homepage:
http://www.cgpsmapper.com/
Free verzia tejto utilitky ako aj platená verzia je na domácej stránke.
Free verzia cGPSmapper, tá úplne postačí pre bežné potreby, je na stiahnutie aj tu:
Link na ulozto:
http://jdem.cz/ujqe9
Jeho platená verzia s liečivom je tu:
Link na ulozto:
http://jdem.cz/ujqf3
Stiahnúť, rozbaliť, zložku cgpsmapperFree nakopírovať napr. do C:/program files.
V GMapTool v nastaveniach určíme cestu k súboru cgpsmapper.exe (viď obrázok)
a môžeme spokojne pracovať s GMapTool 8-) .
MapSetToolKit
Homepage:
http://sites.google.com/site/cypherman1/
Pomocou tejto utilitky môžeme napr. inštalovať mapy formátu x.img do MapSource a robiť iné úkony .
Návod:
Rozbaliť, spustiť, zadať cestu k programu gmaptool a cgpsmapper:
Program je free, na stiahnutie je na domácej stránke alebo tu:
Link na ulozto:
http://jdem.cz/ujqg8
Pre pohodlných:
Ak neviete zistiť ID map (FID), použite utilitku Map ID Finder
Pomocou tejto utilitky zistite ID map nainštalovaných v PC a aj v gmapsupp.img
Link na hellshare:
http://jdem.cz/ujqh4
Naposledy upravil karolE51 dne úte pro 04, 2012 7:05 pm, celkově upraveno 19
Důvod: Pridaný nový gmaptool
Re: Garmin BaseCamp, MapInstall a iný software
Příspěvekod karolE51 v úte pro 04, 2012 6:59 pm
Patcher pre BaseCamp a MapInstall
:pd
Odteraz si môžete stiahnuť obidva programy z oficiálnych stránok alebo z príspevku vyššie a vyliečiť si ich sami.
